- All Mazdas!
CorkSport is pleased to announce the all new CorkSport Short Shift Plate designed specifically for the Mazdaspeed 6!
CorkSports Mazdaspeed 6 Short Shift Plate has been designed to provide a 33% reduction in shift throw for more spirited driving. The unique design of our shift plate provides maximum benefit to Mazdaspeed 6 drivers by changing the geometry at the shifter end to remove the feeling of synchros where it is most noticeable, in gears one and two, and bolts directly to the car eliminating the need to bolt to the factory or an aftermarket counterweight.
Unlike some of the other shift plates on the market today, because the CorkSport Mazdaspeed 6 Shift Plate installs on the shifter end of the transmission, it eliminates any possibility of binding or rubbing on the shift links that shift plates installed at the transmission end may cause. It also makes installation a breeze, taking just 15-20 minutes install, allowing for customers to quickly transition back and forth between the factory shifter to short shifter if they so desire.
Made from precision machined steel plate with a powder coated black finish, the CorkSport Mazdaspeed 6 Short Shift Plate is built for lasting durability and good looks. It comes with all the needed hardware, full color installation instructions, and is backed by CorkSports full two year warranty.
The CorkSport Mazdaspeed 6 Short Shift Plate is available today for just $69.00 and can be purchased from CorkSports online catalog at www.corksport.com
