Details:
The JBR Tru-Torsion Competition Rear Sway Bar is for the serious auto-x and road course enthusiast. This is the same bar being used in the JBR Sponsored #85 All Out Auto Motorsports Mazdaspeed 3 running in the IMSA Continental Tire Sportscar Challenge Series
Constructed out of 1.25"OD x .250 wall 4130 Chromoly tubing with thick solid steel arms. The JBR True Torsion Rear Sway Bar is TIG welded inside and out then the ends are capped. Powder coated for ultimate corrosion resistance. The 3-way adjustability allows you to fine tune the handling for the street, auto-x track or road course
The JBR Tru-Torsion.250 Sway Bar Kit Includes:
Specifications Simulating 1" of body roll:
Stock Sway Bar setting:
MAZDASPEED 3 is 479 lbs/in
MAZDA 3 & 5 is 228 lbs/in
JBR Tru-Torsion 3-Way Adjustable Sway Bar Settings
Stiff setting is 1371 lbs/in
Stiffer Setting is 1596 lbs/in
Stiffest Setting is 2011 lbs/in
- 1 Tru-Torsion.250 Rear Sway Bar
- 2 Tru-Torsion Billet Brackets with Grease Fittings
- 2 New Polyurethane Bushings
- 4 Class 8.8 mounting bolts bolts
- Installation Grease
- Installation instructions are available in our support section
- Shipping is free in the US & our Hassle Free Lifetime Warranty is included
