Hi guys I just got a 1993 626 at the auction for a winter car. It was the "little old lady's" car, and its only got 62k miles on it. Its also in really good shape, one owner, no paintwork, etc.
Everything works fine, except for the transmission. I'm trying to figure out what it is...I got a flashing "hold" on the dashboard, which I can assume is a sign of transmission trouble. The problem I'm having is coming from a stop. The car will drive almost like a go cart or CVT...the rev's hold at 1500-2500rpm while the speed eventually picks up. Eventually it will kick violently down into first before shifting normally. Its only coming from a stop. If I put the car in "manual" mode and shift myself, it is better but it still kicks down eventually. However there are no other problems once I am underway, anthing above 10mph. Also, the idle is VERY low, around 200 rpm. I really hope its a shift solenoid or something and not a new tranny, as I understand these cars have lots of transmission problems. Any ideas? thanks...
