New Motor = Small build/upgrades
It is, but it can't hurt. I'm doing everything possible to eliminate oil consumption problems for this motor.
PCV oil fouling a symptom of a problem - not the cause.
x2 for stock ignition.
?Why add gages we have? puzzled.
I would add to the above - a thermoblok intake kit and at least a lightened crank pulley and flywheel.
We don't have a real oil pressure (light comes on when it is too late) and no volt gauge (because I have a pretty big audio system)
I need to find that thermoblok kit and I do have the jdm mazdaspeed flywheel, the 7lb spec/fidanza is too light for me.
Ordered:
Denso Plugwires
Denso Boots
NGK Iridium
AWR Oil pan
Goodridge clutch line - Black
Samco radiator hoses - Black
Received all except clutch line and rad hoses
Ordered:
Intake Manifold Gasket
Intake Plenum Gasket
Throttle Body Gasket
Exhaust Manifold Gasket
Front OEM Motor Mount
Rear OEM Motor Mount
RR-Racing front/rear motor mount inserts
Received all and installed inserts into motor mounts.
Going to order an Outlaw Engineering thermoblock IM spacer kit, so the IM and throttle body gaskets will be up for sale.
Sent payment for P5 injectors, then will send them to get blueprinted and cleaned
Received and sending out tomorrow to deatchwerks for Dynamic Service. Looking for a Perrin fuel Rail.
lets see some pics of that sexy bisch!
Not yet! LOL.
Edit:
Also ordered Prosport Amber/White Oil Pressure and Volt Gauges, and stealthmode//performance oil pressure fitting.
Not yet, will be getting this weekend. I got a little plan going on, but its secret so lets go to pms. :)
Transmission arrived today.
Sent payment for a brand new Perrin Fuel rail for some sexy bling in the engine bay.
Going to Powder coat the intake manifold wrinkle black to match my valve cover and exhaust mani heat shield.
Updated Gasket List:
Intake Manifold
Throttle Body
Exhaust Manifold
Valve Cover
Oil Pump?
Water Pump?
Going to order all gaskets and front/rear OEM motor mounts soon.
Where are you getting the powder coating done? Hey I live in the bay and drive in the city every once in a while. I have the 7lb flywheel and have never had a problem, you get use to it very fast.
Decided to just wrinkle paint the IM myself (VHT makes wrinkle rattle can), but I did get my air diversion panel and valve cover painted by west coast powdercoating. They do good work.
Haven't updated in a while...
Received:
Goodridge SS clutch line
Outlaw Engineering Thermoblok spacer kit
Perrin Fuel Rail
Deatschwerks cleaned P5 injectors
Volt/Oil Pressure gauges
Stealthmode Performance Oil pressure adapter
I think the only thing I am waiting for is the Samco rad hose set.
It's been a while. Updated OP with pics!
Got the manifold separated, masked off, painted, and put back together with the new gasket
How thats wrinkle paint look compared to pc? I've been wanting to do my vc, heatsheild and manifold for sometime but haven't wanted to pay to pc it all.
Check my OP lol. It looks pretty damn close. Also my motor shot in my MOMT entry. My VC and air diversion panel are PC'ed and my heatshield is wrinkle painted.
yeah, I saw the pics, but seeing the real thing is always better than a picture. lol.
Looks good though. Congrats on the win btw, I know you haven't yet but your lead is pretty sealed. lol
Of course of course. You will see it at TBCM!
Thanks!!!
