moxnix said:
Given how low your TQ is coming on maybe the shorter tires and a short shift to 3rd would work better for you?
From this tread..
http://www.msprotege.com/forum/showthread.php?t=123656969
Ive decided to do a bit of math on this as Moxnix's suggestion is very very interesting. With the previous selection of tires and the lessons you learn that shifting is bad, this was an unacceptable option....but now?
Lets see, stock dyno says that I make 144hp@4250rpm and 192ft/lb@3500rpm. The HP curve us a broad plateau while torque is a rather steep peak(kinda the opposite of everything else you see). Engine starts getting asthmatic @5000rpm, redline @6250rpm.
The math says that with 205/60/15s in 2nd gear @6000rpm (1.772 with FD 4.105) Im doing 60.5mph. Same thing with 245/45/16 Hoosiers. Problem is Im way past the fat of the torque and HP peaks. The GS car is using 225/50/15 V710s. They are 1" shorter than the stock tires..that nets me 58.5mph in 2nd. I have found myself between gears many times as this engine isnt a free revver like the F-series and doesnt really net any more speed winding it out. 3rd with 225/50/15s nets me 87mph @6000rpm...but @4500rpm Id be pulling 65mph.....hmmm.
So if moxnix is right, saying I should damn the torpedoes and go for 3rd with even shorter tires, lets see what happens. 275/35/15 would be 2.2"shorter than stock. 2nd gear would be 55.4mph @6000, but if I do a shift to 3rd, @4500rpm I get 61mph right in the heart of the power/torque.
Smaller diameter tires, less weight, lower CG, higher roll centers, better suspension geometry, wider tires for a "heavier" car.......theoretically better gearing. Im liking this...a lot. I may be selling a set of CCWs soon.
Ill be doing some back to back testing with the GS car with the 225/50/15 V710s and 225/45/15 Hoosiers(almost the same diameter as the 275s) to see how the car responds to a 2-3 shift.
Gavin (really REALLY interested in 15x10s now)
