thepepperman
Just found a new product from JGS which attaches to your blow-off valve, but only opens under positive pressure. This means that for those of us running a BOV vented to the atmosphere (VTA), at idle and under light throttle (no boost) the valve remains closed and all the air goes to the engine! This should work even if the BOV valve is open at the time.
http://www.jgstools.com/turbo/index2.html
Basically, as they mention, there will be a slight rich condition between shifts as air is vented but otherwise, the valve will remain closed. Pretty cool if you don't want to run recirculated, or re-locate the MAF, or go with a dual stage BOV.
Thoughts? It doesn't look especially pimp but for $25 it might be a great solution for those looking for a BOV venting to the atmoshpere!
