New 2003 Mazdaspeed Protege owner with a few questions
Hello everyone as the title says I am a brand new owner of a 2003 Mazdaspeed protege. I have a few questions, I pick the car up with 114,000 and here is a list of things that the previous owner did on the bottom of the post.
Now with this car having higher mileage and the list of things the previous owner did, is there another stuff that’s going to start failing soon or is there stuff I should maybe upgrade.
With this car being a higher mileage I am trying to take a proactive roll and replace things before they break and leave me stranded somewhere. I am also not trying to get crazy with this car just try to make a reliable daily.
  1. Oil Change (full synthetic)
  2. Coolant check/change
  3. PS fluid check/change
  4. Brake fluid check/change
  5. Spark plugs check/change
  6. Air filter check/change
  7. Battery load test
  8. Can of Sea Foam and Fuel System cleaner in gas tank
Hi thanks for the response all that stuff has been done. I have already but two fuel cleaners through there going on my 3, should I still run a can of sea foam through it.
