ornithology
I'm going to be picking up a 17x7, 205/40/17 set of wheels. Only issue is it is +40 offset. Need some feedback on whether this will rub or not or if it is a good choice. Should I up the size to 205/45/17? Thanks all.
Thank you so much for the direct answer. Looks like I may be able to sport some new wheels soon!
Just curious though, what if I go with a higher aspect? like 45 or 50?
The lower the offset, the more "poke" your wheels have (the farther they stick out). I am lowered over 2" from where your ride height would be, and I essentially have a +40 offset as well. I am running a little bit of neg. camber and have my fenders rolled to avoid the rubbing, but with a stock ride height, there shouldn't be any issues.
If there are, there are easy options to offset the rubbing. You can get camber bolts (They run anywhere from $15-$35) that a tire shop can install for you that will take care of any rubbing. You can install them yourself, too. But you will be sorta guessing on the exact camber that you're dialing in. The tire shop can use them to adjust your camber while measuring it with their laser systems.
i'm running the 17" mazdaspeed miata racing harts on my 2000 protege sedan with 205/40/17 tires, and have no rubbing issues, even after installing the tokico hd/eibach pro-kit combo. iirc, the racing harts are 17x7 with a +40 offset too, so you shouldn't have any problems. my only issue is that the ride is a bit stiff, but nothing i can't get used too. next time though, i might just get 205/45/17's or 215/45/17's for a softer ride. someone on this forum is running 205/50's on his 17's, and that might be another option for you.
