I've searched and searched, and I have nowhere else to go.
So, first, let me say hello to the forum as this is my first post.
Secondly, my wife's P5 parking brake won't stay up, at all.
I had the thing out and "enhanced" the teeth in the locking plate thing, but that did nothing. The teeth are more pronounced, but it helped not one bit.
I adjusted the brake cable to tight and loose, and everything in between. No fix.
I called the dealer, and they want $140 for a new assembly. Trying to find a workaround.
I have noticed that when I pull the brake up and pull out on the release button (to further engage the lock into the teeth) it does stay up, so I might just need a stiffer spring in the release button mechanism. However, I have no idea how to get the brake handle grip off, or if I can even access those internal workings.
I see they sell aftermarket upgrades on this (the handle grip), so there has to be a way to get in there, but I need help with that.
So, it comes down to this:
How do I get the parking brake handle off?
If that doesn't work, where should I look besides the dealer for a entirely new brake lever?
And, is there anything else I should try?
Thanks for any help out there!
Jeff
Jeff
