Need Help
cbafever
Ok when I removed the rear badge one tab broke off still inside the trunk. I was trying to pull it out with my fingers, no luck. I tried a bulky set of pliers and ended up losing it through the hole. So now I am down a tab and a plastic housing. Can I get some advice on what to do?
im assuming you want to put the badge back on? Just use the remaining post(s) and glue that baby back on...be sure to do apply enough to cover that hole
I was afraid if I glue it over the hole that water might enter, but if I fill the hole with enough glue then I think I should be alright.
ok, best way to do it is to use double sided 3M take.. works great.. thats what im using
