Need help with "cubby" removal
Krul1
2016 CX5 touring
Want to remove the molded insert for that nearly useless storage area on left side of the steering wheel on my "16" I was able to reach under dash and try pushing it out but no luck. Does anybody know if I can get this piece out without removing the lower left side dash panel?
There's probably a little catch tab that needs to be depressed with a thin plastic wedge tool. Press the thin tool under the trim, once it stops, apply pressure and a slight prying motion.
