- 2003.5 Titanium Gray MSP #1699
I need help! I'm ordering the BEGI FMIC, but I want to figure out my BOV setup before I do in case I need to have a different flange welded on. I currently have the Forge BOV on the stock plastic IC pipes. It works well, but I do get stalling occasionally. Since I'll be getting hardpipes now, I thought it would be better to switch to a BOV that attaches with a flange rather than a silicone hose like the Forge does. I've done my research & the GReddy Type S seems to be the most common choice (& I can easily get that flange welded on). I saw the stickied thread, but it doesn't sound like the GReddy works perfectly unless you also run the stock BPV. I don't have any turkey with my current setup & I'd like to keep it that way. I don't necessarily need a BOV, but I just don't want any stalling once I get the BEGI.
So...what I need to know is which BOV/BPV setup you recommend for no stalling & where I should get the flange welded onto the hardpipes.
