Hihi
this is what i could find about the rx 8.. Hope it helps..
12volts
yellow (15A)
ignition harness
Starter white/blue + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/green + ignition harness
Second Accessory white/red + ignition harness
Keysense pink/black + ignition harness
Power Lock lt. green - driver kick, door harness
Power Unlock same as power lock wire
Lock Motor red/blue 5wi driver kick, door harness
Unlock Motor red/black 5wi driver kick, door harness
Parking Lights+ black/red + driver kick, harness to rear
Parking Lights- lt. green - headlight switch
Hazards orange - hazard switch
Turn Signal(L) green/yellow + turn signal switch
Turn Signal(R) black/red + turn signal switch
Reverse Light red/yellow + driver kick, harness to rear
Door Trigger black/blue - driver kick, harness to rear
Dome Supervision green/black - driver kick, harness to rear
Trunk/Hatch Pin brown - driver kick, harness to rear
Hood Pin purple/white - pin switch under hood
Trunk/Hatch Release yellow - release switch
Power Sliding Door N/A
Factory Alarm Arm green/red - driver kick, door harness
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock
Tachometer NOT blk/wht, blk, or wht/blue ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire black/blue + brake pedal switch
Parking Brake gray - parking brake switch
Horn Trigger green/blue to green/orange - horn switch
Ingi.
