soundbombing
I have joe's mbc on my msp. i also have cai, i/c, 2.5" piping. the valve is almost all the way out and it won't go lower then about 9psi. i hit fuel cut on any cold occasion and sometimes in the day when i shift to third. on a hill with a load say hello to the brick WALLS! I've check the valve for obstruction internally and all the lines and have zip tied them down.
how i have it installed is from the line from the wastegate it goes into the mbc, then from the mbc to the tee. one part of the tee goes uptoward the intake plenum and the other is for the aftermarket bov which has a check vavle on it. so does this sound right. i can raise the boost but can't lower it down to 8 or stock.
thanks for any help.
