chitownMS3
hey guys, j/w
This is what I've found so far "constant power is the big red wire, in the omega one we have ignition 1 and ignition 2. We wire ignition 1 to constant power and ignition 2 to the green wire w/yellow stripe. Then obviously you have to ground it, I used a bolt that is behind the panel where your right foot is when you're driving. Hope this helps."
this is all I have found and it says nothing about a fourth wire and I don't know what the ignition 2 wire is on the module, I can't find that anywhere on the instructions
