mspracer21
- mazdaspeed
can anyone post pictures of eibach sportlines installed, and s tech spring installed.
Notorious said:I have goldline springs and the drop is about 1.8 inches all around. The handling on them are very awesome. I believe the owner of goldline used to do eibach springs but has recently seperated and created another brand. They are available through SPD racing for 130 bucks i believe. Chris is the man to talk about getting them.
wicked said:(silverpro I used goldlines before and was very pleased. they are a higher spring rate than eibachs,so you feel the road more,but the handling makes up for it.
the tokicos blues are an upgrade for most stock cars,but as far as aftermarket goes they are one of the worst made! the only 2 i've seen worse were the TRD and eibach struts. but eibach springs are pretty good i'd say
if you want a good setup id combined eibach pro kit with tokico illumina or KYB gr-2's you would be most pleased with the drop and performance
