- 2008 Mazda5 GT
Wouldn't ya know that this is my first time doing coilovers and I happen to have one that offers a great benefit, which also turns out to be a thorn in the butt. The YellowSpeed COs use a pillow ball top mount. This means the top can rotate and TILT (guessing 20ish degrees). This removes tension that typical COs endure which some lead to creak/pop/noises. The problem is that since the top tilts/rotates, it's quite hard align and force into the shock mount. When I try to jack the mount up, it moves the shock body at an angle. Doesn't help that only the front is on jack stands (gravity pulls it back slightly).  Yes, lots of oil/grease but the issues is getting it aligned.
Any ideas? I'm thinking a hone to clean and widen the radius a tad and a crow bar to pry (need to find leverage) the mount open a bit more. Thoughts? The OE shocks came out pretty easily.
	 ) description…
) description…
	 .  For anyone doing front shocks, MAKE THIS THING.  Super easy to make, cost nothing, and save yourself a lot of frustration.  I will make a better looking one with a hex socket for a keeper.
