need help from some NJers
2003 Spicy Orange MazdaSpeed Protege
hey guys i have the konig reasons and my lug nut key just broke. i was wondering if anyone around the ocean county area has the key for the lug nuts so i can possibly borrow it to get my rims off until the one i ordered arrives? thanks for the help
Are you plannig on replacing the lug nuts? I ask because you can use a 12point socket, hammer it over the lugs and break them lose that way, 19-21mm should work. You will also need a screw driver to knock the lug nut lose from teh socket after it's removed.. Again this is only if you plan to replace the lugnuts.
Hey man, I am from the Manchester Area of Ocean County. If a Mazdaspeed6 Lug nit key is the same as yours, I can be in Toms River in no time.
my lug nut key is from konig tho. . . . so its different from whatever mazda had i would need a konig lugnut key
