Need help finding names of hoses attached to transmission
Col. Scimitar
Mazda 3 2007 2.0 ltr
Update: finally got a hold of my local dealer by phone and was told PART# FNY0-22-91X was a small kit to replace the part I was looking for but I was still hoping someone could link me to a Parts diagram so I could see it. Thank you, having a little trouble navigating the forum cause i'm a total noob.
Got my car inspected a couple days ago. The mechanic noted a small leak coming from a hose atop the transmission. The hose appears corroded and is only about 2 to 3 inches long and does a kind of L bend. It's on the drivers side I believe he said below the air box. The mechanic didn't know what the part was called as it was not a mazda dealer. I purchased my car as a used car and don't have the manual. Any help would be appreciated.
I have the Mazda3 I 2007 automatic with 2.0 ltr engine.
Thanks ill check it out. i've started finding references online but the kit seems to be less than the oil pipe itself so i'm guessing I'll need both. I am pretty sure its the pipe I need under parts # FNK119930A. I'm going to do my best to get into the dealer on Tuesday after the holiday.
