I have a 2010 ms3 for about 3 months, my mods are su tip, Cobb Sri, Cpe dp w/ hf cat. Every thing was fine till I deleted a resonator. A day after I deleted the resonator the cel came on. Anyone have any ideas? Pls help!
Yea it's got bout 2.5k on it no dash hawk, both o2 sencors are fine. The obd2 I was using couldn't read it cos it was a 2010. I read some that the new 2010's read the airflow diff. When using a down pipe but I'm not sure?
i have the same issure with u and the same mod u got.but i reset 3 time of the ecu, it came out with different codes? all these happened after PTP PCV installed. i had those setup for 10K no problem at all(im ok with the smoke). i
Yeah the Cobb intake has an oversized MAF Housing (relative to stock) and that P0171 code indicates you're in the 20% Long Term Fuel Trim with high short term fuel trims as well. No way to fix it other than reducing that inside diameter. Maybe shove an appropriately sized silicone hose in the MAF Housing to reduce the diameter. Otherwise, buy an intake that was built to work on your car. Ours runs an average of 6% for LTFT with the sizing we chose on the housing ID.
