Need Help, Asap!!!
coote
2002 mazda protege es
i'm trying to install the ractive fpr, but i'm having some problems. gas is leaking everytime i crank up the car. everything is as tight as i can get it though. i can't see a hole in the hose, so i don't know what the problem is. if anyone has had this same problem or can offer any advice or help, please let me know ASAP!!!
thankx!!
the gas is leaking from where the hose connects to the little adapter thing they give u that goes on the fuel rail.
well, i found out what the problem was and it's all good now except for the fact that i can't get the pressure below 48psi, no matter how much i loosen or tighten the adjusting screw. it's also harder to start the car now. anyone know what the problem is? does the ractive fpr suck, or could it just be a bad one they sent me? thanks!!
