Hi everyone, I replaced the rear brake pads on my 2018 CX5, and now I am having trouble with my parking brake not fully disengaging from one of the discs, causing the pads to drag slightly. I have a lot of experience with brake pad replacement, but this was my first time replacing pads with an electronic parking brake. I assumed it was the same as most other rear calipers, so I rotated them clockwise back into the bore. When I noticed the drag, I looked up the proper procedure, and I learned that you have to put the calipers in "service mode" before retracting the piston. Great. So I figured if I "reset" them using service mode after the fact, it would just reset the positioning automatically. Nope. Tried it several times and it will not fully release pressure on the pad after the parking brake is disengaged. Does anyone know how I can reset the caliper? I was thinking of just rotaing the piston back counter clockwise, but I don't know how far to go, and I wanted to check before I make things worse. Thanks for the help!
