I attempted to "calibrate" my Nav system because it seemed to be a little-bit off from reality. Example; at 1/16 or 1/32 scale, It would occasionally show inaccuracies such as showing I already passed a road the was still ahead of me, or vice-versa... showing a road I already drove-past as one coming-up.
So... I cracked-open the manual and tried calibrating it. I drove to a residential neighborhood with no traffic and stopped in the road where a perpendicular street met with the one I was on. So I was right at a noticeable junction on the map. I zoomed-in... told it to calibrate... set the cross-hairs EXACTLY where my car was (or should be) and set orientation (no change, it was already correct).
You'd think that was it... right...?
I thought so too... nope.
As I drove-away... it looked like I was driving across someone's lawn on the GPS screen. So I pulled-up to the NEXT street intersection and tried it again. Was zoomed-in as far as it can be. I was as accurate as humanly possible in positioning the cross-hairs... hit enter... yet still... the tracking seems a little off.
Is it just because the GPS accuracy is not *that* granular and it "approximates" the location and visually "snaps" your position to a "known" road on the map...? or is my calibration still out-of-whack...?
Do any of YOU have GPS accuracy issues...?
Thanks in advance...
-scott
-scott
