The Ford 2.3 is an OHC engine. There are huge amounts of power to be had with that engine ie 300hp NA. This is because it's been developed so much, mostly because of Formula Ford action.
I know I come across as hard-edged and unyielding Akhilleus, but I try to tell it like it is.
As with my carbs, there's only ONE reason for that mod....the sound. I realize that it may or may not even make as much power as even a good intake, but oh man..the sound....
And there's no doubt, I'm just as interested in seeing how indexing the plugs works out for the FS. Hell, I'd love to be proven wrong, so I can do the mod myself. NA is all about one hp here, two hp there.......
Plug indexing would have to be done on the dyno, and there are a few things you'd have to take car of to insure accuracy. You'd have to baseline with new extended reach plugs first. Just to make sure having new plugs in itself didn't give you more power. Also, extended reach plugs might be able to increase compression just enough to give you a marginal increase in hp. If THAT in itself gives someone power, I'll want to know, and put some in my own engine.....
