- '13 CWP MS3 & '16 Mazda6 GT
buy me stuff
Rogue said:after Scott splitting his, and other problems I've had with CS parts, i won't buy anything that CS made....
thanx for the reminder. I'll need the MSP radiator to use with the SMIC. Will my stock fans not work with the MSP radiator and intercooler? How hard is it to wire in the slimlines?fLyPiNoY7 said:dont forget about the msp radiator and fans that u'll need...slimlines if u wish...
yeah, i'll get a new clutch. Not sure what I want (stockish or 6-puck). The LSD I'm getting will already be welded from Protegegarage.Gaboost said:Are you getting a new clutch while you are putting in the flywheel and lsd? And speaking of the lsd, get it welded. It seems to be the weak link in the msp transmission.
As far as the fans go, should be able to reuse your stock one. On the msp, the fan covered both the radiator and intercooler.
JDM-P5 said:I wanna see!!!!!
I wanna convert my slowmatic to a 5spd.....any takers?
Ooooh wait...wrong thread.
Shadow102 said:that shouldnt be too hard: Trans, ECU, Gauge Cluster, wiring harness pieces if not all new harness, clutch, flywheel, pedal assembly, shift linkage, shifter
thanx man. they have some vendors that have the turbo cheaper than **********.Gaboost said:If you are looking just for turbo items in general, check out honda-tech.com's for sale section. That's where I bought my CE28 wheels from. You may be able to find a good deal there.
i honeslty don't know. I'll definately find out what supporting mods will be needed to run the injectors.Lil Freek said:um... does the MSP ECU like 440cc injectors?
