My new mod.
Rob.Tuner
Should add like 30 hp and vtac.
This pipe used to swell under boost. Finally glad I got to change it out and such.
So I guess this is my new boost signal, which is closer to the turbo. This is good right? Before it used to be on the cold pipe.
How did you mount that brass nipple in the aem pipe? Did you just put a nut on the inside of the pipe and screw it on? What did you seal around the edge of the threads with. I have the same inlet pipe on the way, but it's backordered.
i just drilled a hole small enough so that it would thread in and i sealed it with silicone. i dunno if it's still there or not.
