Hey guys/gals, I just purchased my first Mazda a couple days ago and fell in love with it. I got a 3yr or 50k mile warranty on it, so I couldn't pass it up.
I love the car. It is extremely fun to drive and it has quite a bit of pep for a stock 4 cylinder, however I have noticed a couple of the usual MSP problems and wanted to get a little bit of the pros input on this. Keep in mind this is my first Mazda and also my first turboed car so excuse some of the dumb questions that I may have.
1. I bought the car with a CEL code of p2009, I have read on here from previous posters that it is a VICS solenoid, the white one on the intake manifold. My question is, is there a symptom that follows this other than a check engine light and horrible fuel smell?
2. I had a cylinder 4 misfire pending code the first day i took it home. I then cleared the code and it has never came back since. (about 5 days) Could this be due to the p2009 code earlier?
3. Like many others I am experiencing the fuel cut issue. I have a boost guage installed in the car from the previous owner and from what im seeing is I am only getting 4-5psi tops. Its not a huge deal if it's supposed to be at 7psi but just wanted to make sure all the info is right. The fuel cut seems to happen mostly in 2nd gear when around 2500-3500 rpm and i am also getting hesitation when half throttle making my way into boost. (usually at 10vac) I have read that the waste gate actuator could be causing this? Also the ECU not being flashed correctly (not sure if it has been done) Any other ideas with the fuel cut issue? Other than the standard tune up which will be done soon.
4. I have noticed there is a hairline crack in the callaway exhaust manifold however I don't believe this would be causing a 3-4psi cut. Correct me if I'm wrong.
I know about the routine tune up, however I am short on funds at the moment. Hopefully sometime next week I will get the solenoid along with some plugs. Any plug recommendations and optimum gap info would be greatly appreciated. Thank you for your time.
