ozz said:replace it /can't fix abs
JAC said:Why don't you get a front lip? I think it would cover it and your car would look a lot cooler.
ozz said:it probly won't stay because i don't think the filler will stick to godd plus the plastic flexes alot while driving/unlike fiberblass or metal that can be bonded together just my .02
mazdadan said:If you want to dish out the money, here's what I would do. Remove the bumper cover and carefully fuse the torn parts back together from the back with a soldering iron. Then reinstall the bumper cover and apply some touch up paint. You will still be able to tell it was damaged, but it won't look quite as bad. Plus you won't feel as bad if another rock hits it.
Dimitrios said:Even if you body fill it and "plastic weld" it, it will still flex and eventually break again. It would be a temporary fix to be sure...
ABS (like PVC) is a thermoset plastic. Once it takes shape from the [injection] mold, it will not revert back.
