mx-6 turbo
atila
protege 93 turbo
Is the mx-6 turbo as good has the gtx one cause i just locked mine on my gtx and i have an mx-6 turbo bran new. The flange and intake aren't a problem but does it have the same flow and boost capacity has the vj-20
Yes it does suck it is even worse then your stock one. I have one at home in the closet and it is small. Very not suited for the F2.
he HAS a GTX. and is switching to an mx6 turbo. the mx6 IHI is a bit larger than the GTX ihi. if you can fit up the MX6 ihi. go for a t-bird comressor housing and shaft. should be a nice upgrade to the stock GTX turbo.
i bet you wish you had an FE(naughty). but yes, i would go with the MX6 IHI if you have it on hand.
yes, i know the probe turbo engine is an f2t. but the FE is a crazy engine swap for the F-series mazda engine. the fastest probe right now runs an FE at 25 psi. doing high and mid 11's.
