a fire extinguisher in the rear storage cubby is about as good as none at all
So you have 4 floor jacks for 4 pinch weld adapters?
IMO pinch weld points are better suited for jack stand. If Im going to lift front or rear of the CX-5, Id jack up the front or rear cross member or rear differential case like Mazda Workshop Manual suggested with powerful enough floor jack, then put 2 jack stands under the pinch weld point on both sides. To me, I dont need pinch weld adapter as I seldom actually jack up the car at pinch weld point with floor jack, may be only doing the tire rotation, then I use a piece of 2X4 to serve as a cushion.
Gotcha.
Without having seen how these are configured, or how tightly they lay under the hood, I wonder if you couldn't put a spacer/spacers behind each of those 2 rear mounting brackets. That would extend the distance the struts pushed up the hood. It might not require a lot at the rear pivot point to get exponentially more lift at the front.
Of course, that might require finding a longer mounting bolt to go through the spacers to catch the nut on the hood. And when the hood is closed, the struts would be laying a little "deeper" in the engine compartment...they might not have room to do so without bumping into the body.
If required (and assuming you could get to the nuts and there's clearance), the front mounting post could be spaced up so the struts would lay properly when the hood is closed...there seems to be plenty of thread on those posts.
Just spitballing here.
The linked video explains why the balls should be mounted where they are, for clearance inside, basically.
FWIW, the hood sits higher on my 2019 Sig with the the struts compared to the hood prop.
I agree, the mounting location needs to stay the same. But there may be room to add spacers to get a little more lift.
I was just trying to help out the tall guy with some ideas.
btw: I just received mine this morning!! Gonna put them on later today. I cannot extend or compress them by hand. Sure hope they're not defective.
Hope this helps. It's about a 15 minute job.
You were right. 15 minutes and it's done.
Unfortunately, I dropped the ratchet and it put a hairline crack down the headlight lens...at least, I hope it's the lens and not part of the entire assembly. I can't feel it, but it's from the top all the way down to the bottom. If it leaks, I'm screwed.
Ouch! Sorry to hear that. Done things like that WAAAY too many times.
It's classic me. The one spot it could hit to do the most damage...
That's what happens when you've mostly driven used cars that cost under $1,000. You're not used to nice things.
I'm gonna order a fender blanket.
I must admit that I took a large towel out and covered everything before I started.
Are you sure you cracked it? Mine have a straight line from top to bottom about 8" from the rear. I find it hard to believe a dropped wrench would crack the lens.
Hope it's not cracked...look at the other side.
A good tip, a hockey puck fits perfectly in the front jack up point where the indication marks are, clearing the plastic and the metal bump. I experimented and jacked up the front of the car with no problems. The hockey puck is a great non slip cushion. If you have a Dick's sporting goods, it is $1.99 https://www.dickssportinggoods.com/p/ar-practice-hockey-puck-16anruprctcpckxxxhka/16anruprctcpckxxxhka
But can it withstand the hydraulic press?
In all seriousness I trust the aluminum adapter a lot more than a rubber puck. I have seen a rubber jack adapter shatter suddenly (personal experience) and they don't give any warning.
	And whenever jacking up a car, be observant and careful and gradual, and lower the car down if anything sounds or looks wrong. Don't do what this person did (skip to 3:24). He made many mistakes, used multiple pads, didn't place the jack properly, cranks away on it without looking, doesn't lower the jack when hearing bad sounds, etc.
