Multiple warnings - No Codes?
Joe2718
2014 Mazda 3
My 2014 mazda 3 (40K) came up with the following warnings over the last couple days (~30miles total driving):
Tire pressure warning light (checked pressure and reset, still appears)
Traction control malfuntion light (not the off one)
Check engine
Master warning
Kicker is, a quick dash to the auto parts store yields a grand total of 'No codes'. Has anybody seen a similar issue?
Thanks,
Joe
I have not been to Sonora in forever (used to have family there!) but do you have a Mazda dealer nearby? Car out of warranty? That would be my first step.
Closest dealer is down in Stockton or Elk Grove. They told me to have it towed. Ha, not a chance. Bought a Bluetooth obdii reader, and eventually got a p0504 code out of it. Going to try replacing the brake light switch as soon as amazon delivers it.
Have you tried doing a hard reset? Your brake lights aren't working? Sometimes a flaky battery will cause weird things like that to happen. You might want to have your battery charged and load-tested.
A loose ground connection may also cause weird electrical glitches.
