Mudguard alternatives for Mazda5's with sidesills
simonnyc
Why doesn't Mazda make mudguards/flaps for the Mazda5's with sidesills? Does anybody know of an aftermarket company that sells mudguards for the 5?
the side sills block one of the places where the mud guard is supposed to attach.
Custom Splash Guard Mudflaps 2008 Mazda5 GT
Here are some pictures of custom front and back splash guards for my 2008 Mazda5 GT.
If I remember right they are OEM off a low-mid 90's Honda civic coupe or second generation mid-90s acura integra, I can't recall exactly, but I think they are civic. My bro worked at a tuner shop and they routinely took these things off and chucked them. I know they had honda part number markings, and I think the four are off the same car.
I had these lying around in the garage and almost threw them away a few years ago. As luck would have it, they fit fairly well on the mazda5. The back two fit very well to the body. I mounted the back two to the existing three 'blanks' with speed nuts. The front I had to do more cutting/grinding with a dremel and a bit with the heat gun and leather gloves to get it to hug the fender and clear the "sharp" corner in the sill/skirt. This left a small exposed area where you can see some of the white from inside the wheel well, but it is not really noticable. The front I was able to match one hole to the exisiting wheel well fender screw with a speed nut, the second hole I drilled into the front of the sill and worked in a lock nut behind the sill on the inside. You don't have to remove the sill or tires, you can access the sill from the underside looking inside-outward. The sill is hollow, turn the front tires all the way to one side and you can stick your head in and look, it's tight but do-able.
The mud guards "stick out" about 1/4 inch wider than the fender, and this really helps to cut down on splash up, especially since the car sits so low to the ground. I don't know if I trust them to stand up to snowy winters, but here in So Cal that is not much of a worry. I will see how they hold up during our rainy season this winter.
Mazda really should make some mud flaps for the GT, I bet they would sell better than the cargo cover.
