MSP6 floor jack lifting points
dell-man
I was switching out my stock rims & tires to put on my winter rims & tires, and had a bit of a rough time finding where to place my floor jack and my jackstands. I checked the owners manual, but it only shows the lifting points for the jack that comes with the car. Does anyone know where the proper lifting points are for the car?
there is a knuckle in the middle of the front end that works well for me. Killer is referring to the factory jack points on the sides, right by the wheels.
doesnt really make that much of a difference where
just as long as its a piece of the frame and not body work
generally theres two runners underneat the car that stick down from the bottom of the car down its length on either side....thats usually a good spot
in the end it doesnt really matter as you (I am assuming) are going to use jackstands after you lift it?
Those factory points on the rocker panels - won't they crush when using a floor jack? In the rear I use the spring seats, then notched jackstands on the rocker points to secure it. I use the knuckle on the front crossmember, to lift the front end.
