Thanks for the advice guys
JFC! Notorious, JeffMSP, SpoolinMSP thank you. THAT is the kind of response I was looking for. Not knowing that much about it I wanted to figure out whether it was even possible or even a good idea. You have taught me something and that it what I'm looking for. I asked the question because I wasn't sure and you gave me a response that I can work with.
I see the shortcomings that jeffmsp mentions with the 6-speed, but my main reason for asking was the issue that spoolinmsp brings up. I would prefer the car to be at a slightly lower RPM range when crusing at speed on the highway, but without having to sacrifice low-end performance. I was wondering whether a 6-speed trannie might be the solution.
I suppose that it would be possible to change the gearing of the 5th gear alone to provide gearing more amenable to highway cruising correct? However, our turbo seems to drop off in 4th and 5th gear and changing the gearing this way would only make that situation worse right. Especially between 4th and 5th as now the gearing gap would be larger and cause you to be in a low-boost range for a longer period of time. In other words, you might be able to cruise at high speed with a low RPM range, but it would take a while to get there especially after you hit about 60mph/100kmh?
Rainman
