msp racingharts on 87 FC
the'll fit but look real funny i use my old 16" of my protege5 as rollers for all my FC's i have
The 15mm's would be right, but unless you have changed your lug studs, your lugnuts won't have near enough threads to be safe.
I don't know what width the 16" stockers are, but the MSP wheels are 7". Same as stock TII wheels, but the offset is 55mm instead of 40mm. They absolutely rub in the front on the spring/spring perch. You cannot roll the car with them on there. 15mm spacers should be perfect to remedy that...
supman said:
do u guys think these will fit on a FC? its 55mm offset, 5X114.5.
It will be really hard to get those to fit.... The offset on an FC front is +40mm max with a 235 tire...The tire is what ultimately rub on the coilovers.... the rears fit work because the MS wheels are so narrow...
here is my +35 & +33 offset w/ 17 x 10 and 9's
I can't spelll today.... 235's front and 275 rear... and the MS wheels "might" fit the rear...
