msp eyelids?
would get those but dont have enough money for the cf hood... and it would look a little weird without one...beside i think cf hoods are a little ricey
(smash) Let's not get another thread started on the "That looks ricey" bulls***. I like it and apparently I'm not alone there. Anyway, the eyelids look nice.. Take some pics when you have them installed!
I don't think you NEED the hood to match the eyelids, it looks pimp hood or not.
t3ase said:
I can't tell from the pictures, how does the ram air work on the first hood?
it comes with AEM intake ducting that bolt up to the little le mans style scoop on the driver side of the hood.
I have the eyelids but not the hood and I think it looks awsome. I have a black msp but I am not sure how good they would look on an orange one...
the msp has the same headlights as the protege5 right? i am looking for eye lids as well but dont want to spend the dough to buy the carbon fiber ones so i plan on hunting down some fiberglass ones for a p5
Actually the MSP does NOT have the P5 headlights. The MSP uses the standard Protege lights with a single hi/low beam assembly instead of the dual reflector setup of the P5.
That said, I believe BOTH setups fit into the same space, and with some wiring work (to split the hi and low beam harnesses) you COULD swap from one to the other.
the only diffrence is the inside the protege 5 has the dual beam and the reg sedan has the single high low beam...we have the yellow corner peice and you dint
all 2001+ protege based cars (protege, protege5, mp3, msp) has the same OUTER DIMENSIONS on their website. so all parts are interchangable.
yes eyelids will work, yes, hood will work, in fact EVERYTHING will work unless it interacts anywhere on the car past the rear tires. That's where things change.
so where can i find some kick ass eyelids for my baby? i have looked at my normal spots, but all i can find are vinyl do-it-yourself kits. the carbon fiber are awesome(carbon fiber is my god) but i cant spend $60 on somethign i will prolly paint to match my car. links would be helpful...
