MSP Engine Swap Notes (UPDATE NEW PICS PAGE 2 + 3)
Engine swap is done. Drove the car for 250+KMs now. Started first turn, even quicker than when it was new. Comp test 205-220. Car drives like new. Idles perfect. Pulls harder than my old motor ever did when it was stock. Seems like a high 14 second car without having tobeat the s*** out of it with no mods aside from the exhaust and mounts, 6psi. My clutch looks like new after 100,000KM of hard driving. No heat marks or anything, guess I am not a tard. Only thing I am worried about is the passenger side axle seal on the trans leaked for the first 50KMs but I refilled it and havent noticed any leakage since. Here are some notes to others that are replacing their tired FSDE.
1. When you are removing the oil cooler from the back of the motor you will need to remove the piece your oil filter screws into and get it onto the new motor. All you need to do is crack the nut, unscrew it until it is almost of, then thred the oil filter on about a cm or 2. Then hold the nut with a wrench and the filter with the other hand, twist until the threaded piece is loose from the block. then just install oil cooler on n/a motor.
2. You will need to swap the upper oil pan to get the msp turbo oil drain line to work with the n/a motor. Remove all bolts on the upperpan and do not forget the 2 on the main seal that are attached to the upper oil pan.
3. You will need to swap the coolant lines that go from theback and side of the motor to the front and the housing.
4. Exhaust manifold bolts are torqued to 14-16 pounds. Flywheel Bolts 97-102Nm / 70.9-75.9 ft. lbs Clutch Cover 18-26 Nm / 14-19 ft. lbs Drive Plate Installation Bolts 97-102Nm / 70.9-75.9 ft. lbs
5. If you get confused with the wiring justremember that each connectors is unique so you cant screw it up, if it fits together its in the right place.
6. Protege shop manual for anything you cant figure out:
http://www.pulledover.org/imports/downloads.php
I am very pleased with my swap. It was not hard at all and was worth every one of the 85000 CDN pennies I paid to do it.
MSP for teh win. (first) Ultimate stock appearing buildup begins.
