MSP Engine Parts Compatable w/ MP5
fc3857
Hello everyone, I went to the search bar to find my answer and either I'm really bad at looking or it's not there. But anyway, I wanted to know if parts from the MSP engine like the headers and things like that are compatible with the engine parts from an MP5. It may seem like a noob question but I really want to know more about the car. Thank you.
Are you trying to turbo your car? If not then you can't use the header because it uses a manifold for the turbo.
Other than the turbo stuff everything internal is the same except the main bearing support plate has a fitting for the oil drain. Bearings, pistons, rods, crank etc are all the same
