MS6 from a roll
I know what the car is capable of when it's launched,..but 9 times out of 10 i like to just roll on...rather than beat the hell out of the clutch and drivetrain by revving and dropping.
What is the 0-60 like from a roll? The wrx is quick when launched,..but from a roll it is a dog. Wondered if the same is true with the MS6.
Thoughts?
Thoughts?
Kinda the same thing....All low gear power....Once we get some more upgrade options we should def be able to improve the midrange power.
its 3.91 seconds...the msp6 likes to activate the hidden twinturbo when rolling between 5-10mph.
hahaha..you know what i mean... Sorry, too many hours of work, not enough sleep. How about rolling on from 5, or 10 mph? What is the power like. I assume you have to wait for the boost to build.
Is there a retard smiley somewhere i can use.(stupid) i like this one..
i think it should be fairly better, since you are rolling and you are already reving up...the revs should be around 2.5ks rolling at 10 (i really ahvent looked), so technically its a short way from activating hte boost, which punches around 3k-3.5k...plus awd=faster.
Not fast enough. The top end dies on a stock MS6 b/c the boost pressure tapers off and timing drop. Check and see if you have the latest ECU flash. I believe they are on the 2nd one now.
