Is there away to get the fans to blow air that is the outside temp without having to be heated to 60 degrees. That is the lowest number I can get on the auto setting. In other words can I get the fans to blow without the auto climate on?
If it's 50 out and you want 50 degree air to blow in you're sol. If it's 65 and you want 65 degree air to blow in just crank the knob down to 60 and turn off the a/c.
Read your owner's manual, it should answer all your questions about your HVAC system. Or anything else for that matter. I'm not trying to be a smartass, but it seems no one checks the manual these days.
