dougefresh_
- 2006 MS6 wwp
Thanks dougefresh, Great vid. Sites have been bookmarked, thank you. The shifter looks much smoother and like you said looks more fun to drive!!
You're welcome, and I'm glad that helped.
Nice car..... looks like an Altered Customs FMIC kit.
There are actually 4 "tuning" options, most people don't like the latter 2. You already know of the AccessPort and the CP-E Standback, but there is also the Unichip and the Hypertech Sport Programmer.
As already stated, the AccessPort is only "married" to one car..... it's unlikely you have this, unless the AP was sold with the car (very doubtful). The Standback is a piggyback unit, and from my understanding it must be connected to control ECU, if not connected it reverts back to stock settings (I may be wrong on this).
The Unichip is more of what someone would refer to about the car being "chipped", it's likely if this is left on the car, and can only be tuned by a professional tuning shop that supports Unichip, however people refer to them as Unicrap and don't like them.
The last is the Hypertech, a very very basic tuning element, allows for a few changes by the using, but the maps can only be adjusted and are downloaded from Hypertech.
If you get the AccessPort it really won't be necessary to get the DashHawk, multiple people I know sell the DashHawk after getting the AP because it already shows them the info they want to see. The AP will also display the boost pressure for you AFAIK.
If you have all those mods and you get a tuning solution, an upgraded fuel pump is definitely recommended. You can shop on CP-E, Street Unit, and Protege Garage regarding an upgraded high pressure fuel pump.
Car looks nice man, have fun with it!!!
I have got to say I am truely jealous of how your speed6 came off the lot! It also looks like the top of the engine was painted as well, which makes the engine bay look a lot cleaner without the stock top mount. Gorgeous car, and nice color choice!![]()
Thanks for the Kind response.. I took the car on about a 400 mile trip this week end.. Car drives very nice on the road and very mild mannered until you need to pass or just want to scare the wife a little (pregnant wife so never did really open up). After more reading I think your right I'm going for the AP and skipping the DH. Another noob question.. My BOV I think is set to VTA, how do i verify that and is that the best open? Does the sound lessen when not set to VTA?
Disadvantages
In the case where a mass airflow sensor is used and must be located prior to the blowoff valve, the engine control unit (ECU) will meter out excess fuel because the atmospherically vented air is not subtracted from the intake charge measurements. The engine then briefly operates with a fuel-rich mixture after each valve actuation.
The rich mixing can lead to hesitation or even stalling of the engine when the throttle is closed, a situation that worsens with higher boost pressures. Occasional events of this type may be only a nuisance, but frequent events can eventually foul the spark plugs and destroy the catalytic converter, as the inefficiently combusted fuel produces soot (excess carbon) and unburned fuel in the exhaust flow can produce soot in the converter and drive the converter beyond its normal operating temperature range.
One way to mitigate the problem is to reduce the boost pressure, which reduces the required venting volume and yields less charge over-calculation by the ECU. The air can also be recirculated back into the intake, a typical stock setup for cars with an upstream MAF sensor. The situation can also be corrected by switching the fuel metering system over to a manifold absolute pressure sensor, a conversion that usually requires a compatible aftermarket ECU or piggy-back fuel controller. The MAP sensor monitors the absolute pressure in the manifold at all times and will correctly detect the change that occurs when the valve vents, allowing the ECU to reduce fuel metering accordingly
Hey man, are you located in NM? If so, I kinda know the guy who owned it. Never met him but know people who still know him and stuff. He used to have a GT30 turbo in there and parted that out along with some other stuff. But I'm not sure if that's his car just yet. I know he had that many miles on it.
Haha cool. Yeah, me and a couple of ms6 buddies last night were wondering who bought his ms6. Pretty cool. We were planning on doing a meet sometime once my other buddy gets his build done with. The guys at University Mazda are pretty cool, I got my car worked on over there when I had an oil leak and I had mods on my car then.
Also I noticed two red hoses that run to the front passenger side fender.. Any idea what that is?? almost looks like it could go to a remote oil filter?
