Hate said:Because the stock tires are summer only tires and not meant to be driven in snow AT ALL?
wannabe said:granted. however, the car behaved as a rwd car does in the snow, not a fwd. tapping the gas caused oversteer, in fwd you get understeer.
DSMConvert said:forgot to post this the other day...for those interested this is a list of cars that utilize the Haldex system(page 11)..hehe notice no ms6 listing..
http://www.odette.se/files/Jan Erik Dantoft.pdf
On another note I talked to a few Audi enthusiasts and from what they told me the Haldex system came on the higher end audis, while the "lower-grade" toyoda system was found on the base and entry audi cars...namely any audi with the engine pointing north and south had haldex, while East and West engines got toyoda...which apparently plays a role in the haldex being able to be a rwd setup while the toyoda defaults to fwd... please note I have not confirmed this info, though the people I talked to come from professional racing backgrounds ranging from mechanics to pit crew, to drivers.
psi365 said:Completely incorrect. Being an Audi Master Guild tech I can tell you Audi uses either a Haldex or a torson differential. So far only the TT quattro, and A3 quattro use Haldex (transverly mounted engines). All other Audi's use a torson differential to make them awd.S4's, RS4's, S6's, and S8's even have a 40/'60 split (frt/rear).
So which system is actually used on the MS6? Viscous coupling, torson differentail? How do they control the power biasd? If its controled from the rear differentail, then it is like a Haldex system. If it is controlled at the transfer case then it would be more like an Evo or Sti.
Gandalf said:Electromagnetic clutch - no diff.
DSMConvert said:um psi how am I completely incorrect? you just said yourself that some audi's use the haldex system??? I think what you meant is that I was incorrect on the other means of awd system utilized by the audi lineup. And thank you for clearing that up, like I said I was only going on "shop talk". At any rate please take a minute to read the other 4 pages of this thread and all your questions will be answered. If you're going to jump into a discussion atleast have the courtesy to read ALL the discussion before asking a ton of questions that have already been answered.
Also if you're a master tech then you'd know xfercases cannot have electromagnetic clutches....
DSMConvert said:well I can't explain that karman...all I know is what the engineers and diagrams say..BUT another way you can tell is to go out to a wet parking lot and see if you can do an axis spin...if the power to the rear is over 40% you will be able to do a perfect axis spin. Axis spin - where the center of the car stays fixed and both ends rotate around it..
