MS3 single green wire connector where does it go!?!?!
OK, so in the process of rebuilding the car; I have been taking my time and removing everything carefully and putting/connecting back everything where it needs to go.
However, a few days back, I have dissasembled the entire harness section that's by the fuel pump. When I was done with what was needed to be done I started to connect all the connectors together and was stopped and dumbfounded by the last one!!
Here's the pic:
See, that connector I'm holding. On my car's model (08.5- dunno if it will differ between models) it's a single green wire connector with a black harness. The other pin is flat with an orange circle.
I dunno if I'm over-looking it or something but for the life of me I can't find where the hell it goes. I tired looking at all the "how to" thread but none of them reveal that connector. So, I would appreciate it someone looked into their car and see where the hell this s*** get's plugged into.
Thanks,
Sebastian
PS: as a reward I'll give you a cookie!
Here's the pic:
Thanks,
Sebastian
I mentioned this in a post while I was messin with the airbox
sure looks like a non factory wire, huh.
we all have it apparently
No Idea what it does, mebbe I can trace when the sun comes up
Found it!
Thanks for the reply but as soon as I posted this thread I went back into the garage and found it. It connects to an stand alone connector that's mounted onto one of the small brackets that's by the fuel pump. I forgot that I took that connector off the bracket and taped it up so I could paint the other half of the bracket.
