MS3 or VWGTI which is it?
Its pinstriping tape and can be found in the paint section at pepboys for 4.99
Its easy to put on you just have to be patient on the curvey parts.
dread said:
The accessport should be released by the end of the summer and its not a piggyback, its a reflash for the ecu.
Thanks for the compliment elderly
Is it? (sorry to go off topic) I thought it was a piggy back unit... will I still be able to reflash the ECU back to stock if I need to?
You can reflash back to stock, but some say the dealer would be able to tell the ecu was reflashed if they looked really hard. The new version of the accessport actually makes a carbon copy of your stock map, so any updates mazda has made will still be on the car when you flash it back to stock. Cobb has already cracked the ecu and is tuning as we speak. I would post a link to their forums but its not allowed, do a search on google for more info.
Thanks man, yeah because of the checksums, newer cars with checksums data in the ecu records when the car was flashed, each time it's flashed.... so if the dealer looked for it they would see you flashed the ECU at one time, and thus voided your warranty.... of course you could argue that they performed the ECU flash recall, at least for the MS6s
dread said:
thanks here is another pic
shoulda put it on the mustache
He's referring to the "mustache" red trim that you put on the front bumper (lol)
dude i have a black ms3 i put the mazdaspeed sticker
dread said:
Its not very noticable but I like the contrast with the black.
i put the mazdaspeed stickers that came with the cia like your but on the top part of the same window, i like the red front pin striping(iagree)
