I just put the MS3 exhaust on my MZ3 hatch. The MS3 cat-back exhaust is shorter than the MZ3 cat-back, due to the fact that the way their downpipe and midpipe are, it doesn't need to be as long. What you have to do is go to muffler shop to do the install. What they did for me was cut off the flange that originally connects to the MZ3 midpipe, and weld that to the 2nd cat on the MZ3 if you want to retain both cats. To actually install they will have to cut the MS3 exhaust just before the muffler to get it over the rear suspension and then weld that back together. It's a simple thing to do if they know how to weld. To the guys I had do it 25 minutes exactly and $100. I didn't keep the second cat however, so in that case you have to have a 17" piece of straight pipe welded to the front of the MS3 exhaust and then weld that to the header. Also for sedans, you have to extend the exhaust tip 1.5-2" depending on your liking, I've also heard of people having to also bend the tip to center it on the cutout in the bumper. If you have any questions lemme know.
