chicano565
- mazdaspeed protege
do you guys think the new ms3 engine will be compatible with the msp?
chicano565 said:do you guys think the new ms3 engine will be compatible with the msp?
8cd03gro said:its going to be a major problem putting all that torque down on the msp...
benflagg said:I have been waiting for somebody to do this, it give us msp guys a lot more potential to work with in my opinion
Yes, but imagine having a 6 Speed !!!!gone_fishin said:Swapping out the third gen 1.8 or the 1.6 for the 2.0 is a pain in the ass, and that's protege to protege. It gets even more complicated swapping between models. For all the money you'd spend doing the ms3 swap, you could have made much more power on your protege's original.
Focus said:Yes, but imagine having a 6 Speed !!!!
gone_fishin said:Fitment will likely be an issue. Please correct me if I'm wrong but I read that the mazdaspeed 3's engine is basically the same engine that was put in the mazdaspeed 6 (the 2.3 liter t). Mazdaspeed engineers had to design the ms6 with a domed hood to compensate for the engine's height above the frame. Mazdaspeed did a similar thing to the ms3 by traying the hood slightly to raise it 20mm. Also to squeeze the 2.3 t engine into the bay of the ms3, they had to modify the dash to accomodate it (there's an indentation in the dash panel).
Aside from the various fitment issues you'll run into, you'll most likely run into a host of electrical issues.
Been there done that , well (330 WHP @ 18 psi ) !!!gone_fishin said:Having a 6 speed would be cool don't get me wrong, but wouldn't making 375+ whp and boosting at 16+ lbs be even cooler?
gone_fishin said:Swapping out the third gen 1.8 or the 1.6 for the 2.0 is a pain in the ass.
