axisboldaslove
- 07 MS3 GT Heavily Modified
The car is already up and running. I've taken the car to inline racing to be tuned by Huy Tran. The car is making 308whp @ 14psi (the highest knock i see is .35 and afr's are in the low 11's). There is plenty left on the table and we are going to go for more power once I get another wastegate spring that can hold more than 14lbs. of boost. It shouldn't have a problem making 400whp
good to see that you got your car running finally...that turbo what can you compare it to like could you compare it to the gt30 or etc?
