Around 15 wires total. The only wire that may need to be run into the engine bay is if you are running extra injectors. All but one wire is at the PCM, The fuel pump wire is at the front of the shifter.1sty said:How many wires overall have to be cut or spliced?
Do any have to be run into or from the engine bay?
Are most wires found at the PCM?
Thanks again
Later.........Nick
