C-P pistons made to my specs. 8.5 to 1.azian6er said:one more Q, stock compression or 8.5:1 ?
-B
Where were you Joe. We hoped you would show up. I whated to see how well the smaller turbo would do. Big Tim did 236 with only 8 psi.KzA said:almost positive its 8.5:1 Congrats Nick! I knew that MSP would do it..
We were loking to run upto 20psi. We could not get it to hold anything over 15psi. It would shoot up to around 18psi for about a second if that and then settle down to 15psi. Not sure if it is in the wastegate or by-pass valve.azian6er said:i see. what do you think is a safe boost level for stock compreesion and upgraded internals?
-B
yea if it can still spool lol but yea thats mighty impressiveRyanJayG said:holy mother of God!
slap a GT28rs on there and see what it can do.
DragonEye said:yea if it can still spool lol but yea thats mighty impressive
Something in the curves are off on all of the runs today with all of the cars. This is the newest RunViewer software. On the dyno software we all made a few more ponies and the curves were much cleaner. Not sure what the problem is.azian6er said:what happened between 3750 and 5K on that last sheet? did you let off?
-B
azian6er said:also on those sheets, is that HP and torque shown, or are those both HP curves? Im just curious.
-B
The first, fourth and fifth are both. The second and third are hp and AFR only.azian6er said:also on those sheets, is that HP and torque shown, or are those both HP curves? Im just curious.
-B
MPNick said:The first, fourth and fifth are both. The second and third are hp and AFR only.
Thanks again
Later..........Nick
