starting from LA, then up to vancouver, across the country to ontario, through ottawa, and up, then plane to NYC then across to LA then sydney again - this will be over 2 weeks mind you!!!Brian MP5T said:Where are you going to be in Canada? (shrug)
ahb11m said:starting from LA, then up to vancouver, across the country to ontario, through ottawa, and up, then plane to NYC then across to LA then sydney again - this will be over 2 weeks mind you!!!
soooo having a looky at the map pembroke is 80km from ottawa... i shall work out the real schedule and let ya know by PM
BTW nice car!!!! i just realised that the block has changed colour - damn you and your attention to detail!!!
BlkZoomZoom said:You do realize factory torque to yeild bolts are superior to studs right?
BlkZoomZoom said:you just named everyone that had blocks designed for the use of studs.
vindication said:soo, zoomzoom, your saying with stock bolts and a good gasket we should be fine right? the cometics or something else you recommend? I heard the copper one isn't really all that good either
I know that but even then I heard it is not as hott as people make it to be. but I (dunno)Copper requires a groove in the deck...
igdrasil had someone he knew blow a stock headgasket. forget at what psi. I think it was the pro making around 430whp or something like thatBlkZoomZoom said:It doesn't get any much better than the stock headgasket. And I know so many people that hate headstuds it's not even funny. To add to that I have never seen or heard of anyone blowing a headgasket on a 2.0l, which I can't say for many motors.
I just don't like people saying headstuds are superior, because, well, there not.
